Hi My cpu fan is constantly going on and off and when i stress test my cpu and the temps is rising, the cpu fan then runs continuously like it's supposed to. Is that normal? (SPECS) After market tower cooler on intel Dq57tm motherboard with xeon x3460 cpu. Video attached underneath. Please need help! Thanks.
https://linustechtips.com/topic/1364680-cpu-fan-acting-weird/
Yes this is normal, the cpu fan only turns on when the heat sink can't take the heat away on its on, for example with noctua coolers the fan isn't on most of the time
   Ryzen 5 5600X (@4.8Ghz) |  ASUS RTX 2060 OC (+120 Core, +1125 Memory) |  Ballistix 16GB
ASROCK B450M PRO4  WD Blue SN 550 1TB ‎‎‎‎‎‏‏‎| Crucial MX500 500GB | Barracuda 1TB
 Corsair CX450M | Corsair Spec-Delta
https://linustechtips.com/topic/1364680-cpu-fan-acting-weird/#findComment-14928946
You can go to the BIOS and chage the fan curve, so the CPU fan spins even at lower temperatures.
And there seems to be a problem with 3 pin fans...
Cant lower Fan rpm - Cooling - Linus Tech Tips
My build:
CPU
Intel Core i7 9700 8x 3.00GHz So.1151
CPU cooler
be quiet! Shadow Rock Slim
Motherboard
MSI B360-A PRO Intel B360 So.1151 Dual Channel DDR4 ATX
RAM
16GB (4x 4096MB) HyperX FURY black DDR4-2666
GPU
8GB Gigabyte GeForce RTX2070 WindForce 2X 3xDP/HDMI
SSD
500GB Samsung 970 Evo Plus M.2 2280
HDD
4000GB WD Red WD40EFRX Intellipower 64MB 3.5" (8.9cm) SATA 6Gb/s
Power Supply
bequiet! Straight Power 750W Platinum
Case
Fractal Design Define R6
3x bequiet! Silent Wings 3 PWM
https://linustechtips.com/topic/1364680-cpu-fan-acting-weird/#findComment-14928956
50 minutes ago, Podrake said:
Yes this is normal, the cpu fan only turns on when the heat sink can't take the heat away on its own, for example with noctua coolers the fan isn't on most of the time
https://linustechtips.com/topic/1364680-cpu-fan-acting-weird/#findComment-14929004
5 hours ago, Podrake said:
Yes this is normal
Nope.
-Scott Manley, 2021
https://linustechtips.com/topic/1364680-cpu-fan-acting-weird/#findComment-14929363
Check its actually attached to a "CPU" fan header, because that kinda looks like its attached to "case" fan header.
-Scott Manley, 2021
https://linustechtips.com/topic/1364680-cpu-fan-acting-weird/#findComment-14929378
