Budget (including currency):
Country:
Games, programs or workloads that it will be used for:
Hi I wanted to check with you guys whether the components will fit and if there are going to be performance issues. I am mainly going to be using this build for both gaming and school projects. Thanks.
[PCPartPicker Part List](https://pcpartpicker.com/list/YCqgGq)
https://linustechtips.com/topic/1364584-will-it-work/
Can you go into specifics on the use case?
https://linustechtips.com/topic/1364584-will-it-work/#findComment-14928313
1 minute ago, New_Storm said:
i just want good airflow for the case and im also wondering if its compatible with the motherboard
Sorry, I meant what you'll be using it for.
It doesn't really seem like you need a system anywhere near this
https://linustechtips.com/topic/1364584-will-it-work/#findComment-14928320
Just now, New_Storm said:
I will manly use this for gaming, video editing and school projects. Or is it too much for all that?
Depends on what games, what software you use to edit videos, how heavy these editing projects are, what these school projects are.
https://linustechtips.com/topic/1364584-will-it-work/#findComment-14928328
