Hey, so I am building a pc that's under budget, I plan on running yuzu emulator on it And some basic games like gta 5.
Parts that I am planning to get:
Processor- AMD Ryzen 3 3300X
Ram- Corsair Vengeance 3200mhz
Gpu: Radeon rx 570
Motherboard: Gigabyte Aorus B550M
SSD- Intel 660p
Power supply- 650 watt 80+ gold ( forgot company name)
Case- idk which one yet
Correct me if I can get anything better for the price. Thanks,  btw it's around 550$
https://linustechtips.com/topic/1364471-building-a-pc/
7 minutes ago, curiousmind34 said:
seems pretty good.
consdidering the prices of rx 570s right now, I would probably buy the system if it all adds up to ~550 USD
It's a diy so it costs less than a pre built and I'm not going rgb, btw rx 570s are like 120$ now I was actually going to go for a 1660 super before the chip shortage, but already had a working pc. Sadly they cost around 300$ now.  And prices may vary at your state/country. 1000$ is like beyond what one would want to spend if converted to our currency.
https://linustechtips.com/topic/1364471-building-a-pc/#findComment-14927447
2 minutes ago, Shivam7652 said:
Anything I should add or change, that is a better alternative?
Try a Cougar MG120 for your case, it's decent for the price and it's the same one LTT used in their $500 AMD Gaming PC video
Also if you're putting a 3300X and an RX 570 in your system you might not need a 650W power supply unless you plan on a major upgrade to any component in the near future, I think going for a semi-modular PSU would more important than high wattage in this case.
https://linustechtips.com/topic/1364471-building-a-pc/#findComment-14927460
I mean I can get a 650W near me for almost the same price as 500w
https://linustechtips.com/topic/1364471-building-a-pc/#findComment-14928745
