My wifi's been pretty bad lately, and I'm wondering if I can replace my bulit-in wifi card. Problem is, I don't know what type of card would be compatible with my pc. Any help would be appreciated!
specs:
Model: HP EliteBook 850 G1
WiFi Card: Intel dual band wireless-N 7260
https://linustechtips.com/topic/1363398-replace-wifi-card/
2 hours ago, G4LAXY said:
My wifi's been pretty bad lately…
What do you mean by this? Have you tried updating the drivers?
…and I'm wondering if I can replace my bulit-in wifi card.
You can try replacing it, but if your wireless environment isn’t optimized or your wireless router is not up to the task, then a new card won’t solve the problem. Have you run a wireless survey to see what your 2.4GHz and 5GHz channel analysis looks like? What make/model of wireless router do you have?
Open up the Elitebook and locate the Intel 7260 WiFi adapter. Take a picture of it.
The 7260 is a half mini PCIe WiFi card.
https://linustechtips.com/topic/1363398-replace-wifi-card/#findComment-14920310
