Budget (including currency): USD$ I don't actually have much of a budget. I guess I'd prefer it to be under 1k$.
Country: USA
Games, programs or workloads that it will be used for: RDR2 and other less CPU/GPU intensive games (I'm fairly casual)
I do not have a PC anymore. All of the parts from the one someone built for me last died (spare parts from them). I have a 960 GPU and I'd like the build to be compatible with that. I'm planning to buy in a few months and as soon as I have a part list. I am not very good at this sort of thing and could really use the help! I already have the case as well. and I only have one monitor right now. I'm more focused on getting something functional so I can play anything rather than nothing.
Thanks in advance for the help, please let me know what else you need from me~
https://linustechtips.com/topic/1362783-newbie-pc-help-please/
1K without a GPU is fairly easy to do.
What case do you have?  It may be worth upgrading that, depending on what it is.
Something like this, without the GPU Would be a great build.  Could skip the HDD if you want, too.
PSU could go down to ~550W as well for another discount.
https://pcpartpicker.com/list/xZvHcT
https://linustechtips.com/topic/1362783-newbie-pc-help-please/#findComment-14916069
Country: USA
Something like this would be a good start:
- 6 core CPU would be fine for gaming, AMD is best choice right now. Could go for 8 cores  (5800X) if you also do heavier tasks like video editing.
- Good CPU cooler
- 16 GB of RAM should suffice for now, can go for 32 GB to be a bit more future proof.
- Nice fast NVME SSD storage drive 1TB should get you up and running. Can add additional storage if you need more space.
- Good gold rated power supply
- The GTX 960 will be compatible and get you up and running. I would suggest upgrading that when GPU prices come down a bit.
- Case is personal preference, this is a popular reasonably priced one.
Good luck!
PCPartPicker Part List
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor  ($269.99 @ Newegg)
CPU Cooler: be quiet! Dark Rock 4 CPU Cooler  ($69.90 @ Amazon)
Motherboard: MSI MAG B550M BAZOOKA Micro ATX AM4 Motherboard  ($89.99 @ Amazon)
Memory: G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 CL18 Memory  ($75.99 @ Newegg)
Storage: Samsung 980 1 TB M.2-2280 NVME Solid State Drive  ($109.99 @ Amazon)
Case: NZXT H510 ATX Mid Tower Case  ($66.99 @ Best Buy)
Power Supply: SeaSonic FOCUS Plus Gold 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($119.99 @ B&H)
Total: $802.84
Generated by PCPartPicker 2021-08-06 15:24 EDT-0400
https://linustechtips.com/topic/1362783-newbie-pc-help-please/#findComment-14916073
- Good CPU cooler
Good luck!
Total: $802.84
Hey thank you for this list, it's very helpful. I have a Corsair iCUE 220T case. I should have mentioned 🙂
I will look at these when I'm home from work!
https://linustechtips.com/topic/1362783-newbie-pc-help-please/#findComment-14916099
It's a Corsair iCUE 220T (https://bit.ly/3yy6iMg this but white). I'll check it out when I'm home!
https://linustechtips.com/topic/1362783-newbie-pc-help-please/#findComment-14916208
