no guarantees that they'll work together in dual channel, but try to get 2 identical sticks as much as possible.
https://linustechtips.com/topic/1362674-help-with-future-build/#findComment-14915138
8 minutes ago, BlueTrex said:
So I can't find any 16 gb ram kits in my area so if I buy 2, 8gb ram sticks and use them will they work as a 16gb ram kit?
Yeas, try to look for same ones or atleast same brand and speed. Differnet may cause trouble i have experienced one of those..
https://linustechtips.com/topic/1362674-help-with-future-build/#findComment-14915143
