Hardlinks not working (Help)
Go to solution Solved by Frugivore8894,
1 hour ago, 7heo said:
No. You know what, never mind, don't open documentation links when asking for assistance. Good luck.
I did actually read it but I found a better solution anyways.
So about a week ago I asked for a way to get my iCloud phots on to my secondary drive  see here. And the solution was Hardlinks i just got around to doing it and I can't get it to work. So here is that I have done. First I right clicked on my iCloud phots in file explorer and clicked Pick link source.
Then I went to where I want my photos and right clicked the Drop As...
But the option for "Hardlink" is not there. I have tried multiple times and it wont work.
Thx for any help.
https://pcpartpicker.com/list/Qm9Mwc
Main Project:
A desk that has a hatch that opens in the middle of it and then goes down flush with the desk.
Other projects I am working on
  • Sleeper TI-99 4A
  • Second Keyboard
https://linustechtips.com/topic/1362019-hardlinks-not-working-help/
Are you selecting a real folder or the "Pictures" folder-that-Windows-creates-out-of-multiple-locations-but-really-isn't-a-folder?
Main System (Byarlant): Ryzen 9 5950X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 32GB G.Skill DDR4 3600MT/s CL16 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 990 EVO Plus 4TB | Corsair RM750X | StarTech 4× USB 3.0 Card | Realtek RTL8127 10G NIC | Hyte Y60 Case | Dell U3415W Monitor | Keychron K12 Blue (RGB backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB DDR4 3200MT/s (soldered) | Vega II 384SP Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi | Asus 2.5G USB NIC | Asus ProArt PA278QV | Keychron K4 Brown (white backlight)
Proxmox Server (Veda): Ryzen 7 3800XT | ASRock Rack X470D4U | Corsair H80i v2 | 128GB Micron DDR4 ECC 3200MT/s | 2× Samsung PM963a 960GB SSD / 4× WD 10TB / 4× Seagate 14TB Exos / 4× Micron MX500 2TB / 8× WD 12TB (custom external SAS enclosure) | Seasonic Prime Fanless 500W | Intel X550-T2 10G NIC | LSI 9300-8i HBA | Adaptec 82885T SAS Expander | Fractal Design Node 804 Case
Proxmox Server (La Vie en Rose)GMKtec Mini PC | Ryzen 7 5700U | 32GB Lexar DDR4 (SODIMM) | Vega II 512SP Graphics | Lexar 1TB 610 Pro SSD | 2× Realtek 8125 2.5G NICs
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / TEAMGROUP MS30 1TB | Corsair CX450M | Viewcast Osprey 260e Video Capture | TrendNet (AQC107) 10G NIC | LG WH14NS40 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Workbench (Doven Wolf): Lenovo m715q | Ryzen Pro 3 2200GE | 16GB Crucial DDR4 3200MT/s (SODIMM) | Vega 8 Graphics | SKHynix (OEM) 256GB NVMe SSD | uni 2.5G USB NIC | HDMI add-in module
Network:
                       ┌─────────────── Office/Rack ───────────────────────────────────────────────┐
Google Fiber Webpass ── Cloud Gateway Max ══╦═ Pro XG 8 ══╦═ Flex 2.5-8 ══╦═ Doven Wolf
                      La Vie en Rose (DNS) ═╬═ Narrative  ╠═ Veda-NAS     ╠═ La Vie en Rose (vmbr)
                                Veda (DNS) ─┘             ╠═ Veda (vmbr)  ├─ Ptolemy (vmbr)
╔═════════════════════════════════════════════════════════╩═ Ptolemy-NAS  ├─ Veda (Mgmt)
║   ┌ Closet ┐      ┌───────── Bedroom ─────────┐                         └─ Veda (IPMI)
╚═══ Flex XG ══╦╤═══ Flex XG ══╤╦═ Byarlant
       (PoE)   ║│              │╠═ Narrative
Kitchen Jack ══╣└─ Dual PoE ┐  │╚═ Jesta Cannon*
   (Testing)   ║┌─ Injector ┘  └── Work Laptop
     Bedroom ══╝│        ┌─────── Media Center ────────────────────────────┐
     Jack #2    └──────── Switch 8 ────────────┬─ nanoHD Access Point (PoE)
Notes:                                         ├─ Sony PlayStation 4
─── is Gigabit / ═══ is Multi-Gigabit          ├─ Pioneer VSX-S520
* = cable passed from Bedroom to Media Center  └─ Sony XR65A80K (Google TV)
Hard links only work within the same partition. The way they are implemented is by making multiple references to a single object. There is no existing object in the foreign partition for you to refer to. So what you were advised to do unfortunately cannot work.
However I have a suggestion, to achieve what you want another way. This requires an additional partition on your secondary hard drive; with enough space to store your photos (all of them, even the future ones). Once you created that partition, close iCloud photo, head to the Windows's "Computer Management Tool", select "Drive management", and replace the drive letter by the path of your iCloud photo directory.
Once that is done, start iCloud photo again and hopefully your photos will now be on your hard drive. You can verify that by checking the amount of space left on your main drive after you add or remove photos: it should be unchanged. One last heads up: last time I did this was on Windows 7, and most programs weren't designed with that feature in mind; so if I happened to move/create a file bigger than the amount of space left on my main drive, it was failing, no matter how much space was free on my extra partition. Also, I don't remember how it warned me about running out of space on that partition. Windows might have, but I can't remember really.
Isn't windows three-sixty-five just a more recent version of windows three-eleven?
So here is the thing you can't change where the files go for iCloud that's the whole problem.
Main Project:
  • Sleeper TI-99 4A
  • Second Keyboard
No I made my own folder.
Main Project:
  • Sleeper TI-99 4A
  • Second Keyboard
3 hours ago, 7heo said:
You did not read what I wrote.
Yes I did and it clearly says
I might be mistaken but you are say to go to the iCloud app preferences and change where it’s stored. Witch last time I checked ( about 5 days ago) you can’t do. If I am wrong just let me know but that’s the only way to do what you say that I know of.
Main Project:
  • Sleeper TI-99 4A
  • Second Keyboard
Main Project:
  • Sleeper TI-99 4A
  • Second Keyboard
