Hello, I'm choosing the Components of my new build and I'm having trouble with the cpu cooler and the ram.
The cooler is an Cooler master mastercooler ma410m and the ram a 8x4 32 gb 2666mhz crucial ballistix (no rgb) .
The motherboard is an gigabyte b365m d3h
The question is the following:
Will the cpu cooler let me put all the 4 sticks of ram or not?
https://linustechtips.com/topic/1361972-choosing-pc-build-components/
You can detach one of the fan, move it up and stick it with a zip tie.
Won't look great but it will be functional.
