Build plan
1 minute ago, ItsNypz said:Which website do you recommend?
Country Portugal
Budget: 1750€ (those together with case and power supply are already at 1850€)
Portugal PcPartpicker is much better. https://pt.pcpartpicker.com/list/
Here is a list I made. If the GPU was at MSRP you could fit a 5800x.
Changes I made -
-Swapped CPU and board for 5600x + A B550. You could switch to intel if you wanted, but the 5600x is marginally faster than the 10400F, especially with faster RAM speeds.
-changed RAM for a cheaper, comparable kit.
-Swapped SSD for a Sn550. It's a slower drive but you don't need a 970 EVO, the SN550 is more than good enough. (also added a 2TB HDD)
-Made the case a P360A as a placeholder. if you want another case feel free to add one, just make sure it has good airflow and isn't an NZXT one
-Added a 3080 at MSRP, gl finding one tho
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor (€284.90 @ Globaldata)
Motherboard: Gigabyte B550 AORUS ELITE ATX AM4 Motherboard (€125.90 @ Globaldata)
Memory: Kingston HyperX Fury 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory (€79.90 @ PCDIGA)
Storage: Western Digital Blue SN550 500 GB M.2-2280 NVME Solid State Drive (€57.00 @ PCDIGA)
Video Card: NVIDIA GeForce RTX 3080 10 GB Founders Edition Video Card (€900.00)
Case: Phanteks Eclipse P360A ATX Mid Tower Case (€69.90 @ Globaldata)
Power Supply: Corsair RM (2019) 750 W 80+ Gold Certified Fully Modular ATX Power Supply (€89.90 @ Globaldata)
Total: €1607.50
Generated by PCPartPicker 2021-07-30 17:50 WEST+0100
