First of all, please try to make your thread titles descriptive of the actual topic you're asking about. Every day there's probably a dozen threads posted on these forums just titled some variation of "help pls."
Are you asking for recommendations on CPU and memory? What is your budget? What do you intend to do with this PC?
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1360888-help/#findComment-14902270
2 minutes ago, CYBERDAN said:
gaming and may upload
This is not informative.
"Gaming." Meaning what? What types of games? What resolution and frame rate do you want to play at?
"Upload." Uploading what? Pics to Facebook?
And still no info on your budget.
https://linustechtips.com/topic/1360888-help/#findComment-14902274
So you have "500"... in what currency? Is 500 your budget for the entire rest of the PC build? CPU, memory, GPU, storage?
And you have two 144hz monitors I am going to presume run at 1080p resolution, so effectively you have one because gaming on three monitors is kind of a thing for some types of games but gaming on two monitors really isn't.
Once again... what games do you want to play? What does "upload" mean?
https://linustechtips.com/topic/1360888-help/#findComment-14902285
6 minutes ago, CYBERDAN said:
it save as u go at minute buying bit in i have case and power supply im looking at intel having xbox on pc i have two moniters aoc 25 in 144hz so im puting bit on desk at minute
1) use the quote button, or we will not see your responses.
2) edit your original post to include more details. Tell us:
- monitor resolution you have
- some games you want to play most
- what country you are buying in.
3) if you already have a B560 motherboard, any of the 10th or 11th gen Intel CPUs are compatible.
4) what does "500 at minute" mean
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1360888-help/#findComment-14902287
