Hi,
Last night instead of Shutting Down my PC my mother put the PC to sleep.
And my dad thought it was turned off and switched of the UPS.
So today morning when I booted it up. I got the Blue Screen of Death.
And automatic repair started to repair the PC.
After some time I got the automatic repair couldn't repair.....................
........srttrail.txt.
So I tried the restore option in advanced
It did not help.
Now can I reset the PC ?
Will it work ?
What else can I do ?
https://linustechtips.com/topic/1360501-need-help/
35 minutes ago, SladeDJWilson said:
Hi,
It did not help.
Will it work ?
im guessing some files got corrupted or something so may need to install the windows again. you can use another pc or laptop to download the windows 10 media creation tool and then put it on a bootable drive and then using this drive, install windows on your PC.
https://linustechtips.com/topic/1360501-need-help/#findComment-14899707
