My PC keeps restarting when I play games and event viewer has designated it as the title issue. I've tried reseating everything and temps aren't going to high either. All power plugs are installed so everything is getting maximum power. Does anyone have an idea of how to fix this?
Thanks
Ryzen 9 3900x
MSI MAG Tomahawk x570
Gigabyte Rx6800
2x8Gb 3600MHz Corsair Vengeance RGB Pro
Corsair Rm1000x
https://linustechtips.com/topic/1359804-kernel-power-event-id-41-task-63/
I have the exact same thing.
Specs:
MB: MSI MPG X570 Gaming Plus
CPU: Ryzen 7 3800X
Mem: Corsair Veng. RGB Pro D416GB 3600-18
GPU: Gigabyte 2070 Super Windforce OC
M2: Samsung 970 Evo Plus 1TB
HDD:  Seagate Baracuda 2TB
PSU: Corsair RM850
Case Sharkoon Elite Shark CA200M
AIO: Corsair H100i Platinum
Fans: 3 case fans front blowing in, 1 back of case going out, 2 fan on AIO going out (top of the case)
Benchmark: MSI MPG X570 GAMING PLUS (MS-7C37) Performance Results - UserBenchmark
All Temps are good
Reset GPU OC to defealt settings
Set power setting to AMD Ryzen Balanced, including  HD turn off and sleep to 0 sec and minimum CPU state to 5% and max was already at 100%
I am out of ideas and otions, also not sure what the problem can be, but it starting happening a few days back and i didnt updated or installed anything special except playing some games like New World Closed Beta, SWTOR and GTA 5.
ps. even if i have my pc idle it crashes sometimes while i am for example chatting (text only) on discord or just browsing the web/YT
