I was playing gta 5 on my pc. The specs are given below:
Pentium dual core e6600@ 3.06Ghz
Nvidia GeForce GT 710
6GB DDR3 1033mhz
While playing, the computer suddenly shut down and gave a BSOD stating the "kmode exception could not be handled". Then It collected necessary info and it started rebooting into windows but started to perform some disk check or repair. The power suddenly went off. Now it is stuck in a in a bootloop where the startup repairs tries to repair it and then says it couldn't, then I have the option to reboot again or manual troubleshoot. I have performed chkdsk command on all partitions but no luck.
I would be obliged if some of you awesome guys can help me out on this one.
https://linustechtips.com/topic/1359749-computer-not-working-after-kmode-bsod/
6GB DDR3 1033mhz
Windows prob got corrupted
The most effective ways ive found for dealing with corrupted windows is system restore and reinstalling windows
And how the hell are you even running gta on that thing, i cant even run mc smoothly on my overclocked pentium e5400
Try disconnecting all peripherals first and then see if windows boots
if it doesnt work then you should probs reinstall windows
(clean install recommended)
https://www.makeuseof.com/fix-a-kmode-exception-not-handled-error-in-windows-10/
although i know you cant boot into windows , you should probably see why this error occurs as to not let it happen again
  • 2 months later...
Ive locked the refresh rate to 30 hertz, plus run it at 900p to reduce cpu load. The fps is 15-25, but no stutters, no freezes, no missing textures. It's mostly around 21, only drops below that in grassy or very intensive areas. I am accquainted to that experience, so works for me
