If it needs to be heated up to start, you probably cooked one of the connections on the board. Depending on what it is, it probably needs re-soldered or re-balled.
You could however try removing and re-seating any removable components on the board first, if that fails you would need to take it to a repair shop to be diagnosed and possibly repaired.
