press start button -> type in diskpart -> enter (black window will open) -> type in "list disk"  (without the " ofc) -> see if the device is being listed their, if so then there might be just a wrong format on that drive.
more instructions will follow Mr. Bond, upon recieving the information you will provide after the steps 😄
https://linustechtips.com/topic/1359187-help/#findComment-14899319
