So I started building my PC, and everything was cool, updated bios of the MOBO, installed windows and all, temps were very high so I decided to not use the PC until I get a better cpu cooler, so I bought the kraken Z63, installed it, and now my mobo displays code D6 - No Output Detected. I tried unplugging the AIO cooler, trying the GPU on different PCIe slots still nothing, Here are some pictures and a video of the setup:
imgur.com/gallery/30k5pr1
Specs:
Ryzen 9 3900x msi ventus rtx 2080 Super gskill trident z neo 2 sticks of 32gb each AORUS NVMe Gen4 SSD 2TB MSI Meg X570 Unify Lian Li O11 dynamic XL
keep in mind I had even played a game on the pc before I decided to not turn it on anymore and wait for my new cooler.
Edit:
Tried the card on the PCI_E5 slot and it works! Only on that slot, not even on the third slot
https://imgur.com/JOfUeJk
https://imgur.com/oyzDU06
I updated the chipset bios, Nvidia drivers, cleaned the slots with compressed air, I dont know what else to do
https://linustechtips.com/topic/1359086-msi-meg-x570-unify-d6-debug-code-problem/
Looks like other people solved this issue by ensuring all the power connectors on their GPUs were properly populated with PCIe power cables from their PSU.
If you already have the GPU power plugged in seemingly correctly, maybe try different cables or plugging them into a different rail on your PSU if you can.
Already tried:
https://imgur.com/ZZyShY4
Only two options, still not working 😞
