Hey so I haver a bit of a problem and was wondering if anyone could recommended me a fix or solution
So I have a 3080 FTW3 ULTRA but on idle the temp vary from 55 to 65 degrees and when I play games it jumps up to 75- 85 degrees I have set a curve and i have all my fans on max on MSI afterburner and that just stops it from going to 86 and above. I do play on an ultra wide 3400x1400p at 120 Hz
The case is the Fractal Design Meshify S2 it has 2 140 fans in the front as intake and 120 it the back as exhaust and the top is the radiator/ If anyone has any suggestion please let me know
Thanks.
This is the Build bellow
Pc Build
[PCPartPicker Part List](https://pcpartpicker.com/list/LxJz3Z)
https://linustechtips.com/topic/1358756-help-with-gpu-cooling/
