Hello,
I was trying to connect my nextcloud NAS with my domain but when I point DNS to my IP it takes me to microtik login page my ISP is using microtik to throttle my internet speed how can I fix that I am new to these things so please be a little more specific
Note : I can ask my ISP to change some configuration if I know what to do
sorry for that English xD
https://linustechtips.com/topic/1358694-need-help-with-my-nas/
I forwarded port from my router to the device on which nextcloud is working i can access nextcloud from local IP without any problem
And about my isp using CHNAT i am not sure but most probably yes.
I just want my isp to forward request coming from my domain to my ip. Currently the request doesn't even reach to my router it just stops at that server login page
https://linustechtips.com/topic/1358694-need-help-with-my-nas/#findComment-14888878
22 hours ago, Electronics Wizardy said:
Did you port foraward the next cloud instance?
Is the isp using CGNAT?
https://linustechtips.com/topic/1358694-need-help-with-my-nas/#findComment-14888881
Check for CGNAT by seeing if your wan ip is the same as your public IP.
But if there using cgnat you can't host nextcloud by just portforwarding. You will either need to use ipv6 or setup a vps and use a vpn to host from there.
https://linustechtips.com/topic/1358694-need-help-with-my-nas/#findComment-14888884
I am sure now my ISP is not using CGNAT
now what exactly should I ask my ISP to do for me
https://linustechtips.com/topic/1358694-need-help-with-my-nas/#findComment-14889347
