What brand/model of self-contained CPU water cooling is recommended these days?
It's for a i7 4770K with Corsair 750D or 760T case. Assume a budget less than $300 (in case someone wants to suggest something extreme).
Ryzen 9 5950x | NH-D15 | ROG STRIX X570-F | G.Skill 32GB DDR4 | MSI Ventus RTX 3080 | WD Black SN850 1TB PCIe 4 | Samsung 850 EVO + 860 EVO 1TB | Corsair 5000D Airflow
Dell S3422DWG | Dell S2721DGF | Corsair K70 RGB Keyboard | Logitech G502 Lightspeed | ATH-R70x
https://linustechtips.com/topic/135852-recommendation-for-cooling/
nxzt kraken x60
corsair h105
swiftech h220
Specs
Corsair H100i, or that expandable one Linus talked about a while ago from Cooler Master.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
I comment 1 on these!
its better than those prebuild watercooling solutions
- teamspeak.ltt-unofficial.com
- teamspeak.ltt-unofficial.net
- teamschnitzel.ltt-unofficial.com
- teamschnitzel.ltt-unofficial.net
cpu: Intel sandybridge-E 3930k @ 4.2Ghz
cooler: corsair h100 @ full speed push-pull
motherboard: Asus Rampage IV Extreme
gpu: 2x EVGA GTX660's & 1x EVGA GTX980
ssd: 2x samsung 256GB 840 pro raid 0
ssd: 1x samsung 1TB 840 evo
hdd: WD green 3TB
hdd: Seagate Barracuda 1TB (st1000dm003)
hdd: Seagate Barracuda 1TB (st31000520as)
psu: corsair ax1200i
ram: 8x 4GB corsair platinum @1866mhz
case: coolermaster cosmos II
age: Do the math (summer 2012)
monitors Main: 8x LG 22EA53 1080p 60hz
monitor Extra: 1xiiyama prolite G2773Hs 1080p 120hz 27"
os: windows 7 pro (64-bit)
keyboard: logitech g19
mouse: corsair m60
Lenovo T550
RaspBerry pi webserver:
Status: Offline.
Nas:
StatusOffline.
PC straight to the modem/router/switch/DHCP-Server/... with a 20cm (+-8inch) cat6a patch cable because same price as cat5.
ISP: Telenet (belgium)
Speed: 60Down-4Up (+- 45€/month)
ping to there servers: +-8ms
ping to other Belgians: +-12ms
- wheels for cosmos II
or something smaller;
It's a little dusty, Might want to clean it off
♦CPU: AMD FX-8320 @ 3.5Ghz♦MOBO: Gigabyte GA970A-D3P♦RAM: G. Skill RipJaw X 8GB @ 1600Mhz♦GPU: Sapphire Radeon HD 7770 1GB Ghz Edition♦OS HDD: WD Caviar 5400RPM 500GB (490GB Actual)♦GAME DRIVE: Samsung 840 EVO 120GB (112GB Actual)♦PSU: Corsair CX750M♦CASE: A piece of shit
The Glacier 240L? Nepton 280L?
H220 is the best on that list.
whaaaaaaaaaaaat the x60 is the best AIO
Specs
I think it was the Glacier 240L.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
but really though, Don't get an antec khuler. the temps I get, I might as well be using a 212 evo.
the 3 mentioned above are a lot better. I'd go with the H220
http://www.anandtech.com/show/6716/closing-the-loop-ii-new-liquid-coolers-from-corsair-and-swiftech/4
It's better by 3C while sounding like a hair dryer.
Ryzen 1600@3.8ghz / 16gb 2400mhzASRock B350 ITX / Gigabyte RX 470 4gb / 256gb M.2 / SG13B-Q / Corsair 450w
