My school gave us ipads and typing on the i sound like im punching the screen because im so used to a mechanical keyboard. On my desk i use a corsair k70 my goal and i havent been able to find something yet but does anyone one know of a bluetooth mechanical(preferably blue switches or blue like) keyboard that is small enough to fit in a backpack?
https://linustechtips.com/topic/135765-keyboard-finding-help/
no bluetooth mech keyboards yet sorry or if they are most likely any good
Christian and Proud of it
Please read the CoC        My Build Log
https://linustechtips.com/topic/135765-keyboard-finding-help/#findComment-1805492
damn it. any good keyboards that could be used with ipad that you can think of? even if its a case one?
logitech makes some good mobile keyboard you can check them out here
https://linustechtips.com/topic/135765-keyboard-finding-help/#findComment-1805523
There is at least one but its full size. Check out techkeys.us as they should have it.
https://linustechtips.com/topic/135765-keyboard-finding-help/#findComment-1805610
