Recommendation for BIG + QUIET case
Solved by Chris Pratt,
Noctua recommends A fans across the board now. They're superior to all their other fan types in most applications. The P fans have the highest static pressure, but aren't great at airflow. The F fans are also high static pressure and have better airflow. However, they only exceed the A fans when unimpeded. Similarly, S fans have the absolute best airflow, but only when completely unimpeded.
Also, the Redux line is the budget category. Performance is basically the same, but noise levels are higher. Since your main complaint is noise, I'd avoid those entirely.
Long and short, just get some A12s. If you can fit 140mm anywhere, it would be better to use A14s there, as they'll be even more quiet for the same performance.
