Budget (including currency): None
Country: USA
Games, programs or workloads that it will be used for: Tarkov, Ark, 7dtd, The Crew 2, ETC...
I need help decided what to do. I just upgraded my GPU and RAM, but I feel like I need to upgrade my CPU aswell.. feel free to say anything that would help or even if I dont need to upgrade.
                                Components
Case: Corsair iCUE 4000X Mid Tower
MotherBoard: ROG STRIX Z490-E GAMING
CPU: I7-10700 2.9 GHz (Corsair iCUE H100i Elite Capellix AIO)
RAM: VENGEANCE LPX 32GB ( 2 x 16GB) DDR4 3200MHz (Currently running at 2666 MHz...(Look Below))
GPU: MSI GeForce RTX 3070 Ventus 2X OC Gaming, 8GB GDDR6
PSU: NZXT C850 Fully Modular
Monitors: (Main) AOC 27 27" 144Hz 1080p 1ms Responce Time with Nvidia G-Sync | (Secondary) Z-Edge 27" 1080p 75Hz 5ms Responce Time
Notice how my CPU is not overclockable, I tried installing the RAM at 3200 MHz but it kept blue screening due to "Memory Management" and I believe it was due to my CPU being locked. (If you have a answer, reach out and help)
I looked it up for my motherboard and everthing after 2666MHz it had "(OC)" next to the MHz.. does this mean I need a Overclockable CPU in order to raise the MHz of the RAM?
Also, do you think i should upgrade CPU's, If so do i go simpily i7-10700k OR do i just say screw it and go for a i9?
https://linustechtips.com/topic/1357171-upgrade-cpu-or-no-also-help/
XMP can be enabled without a K-series CPU, so your 10700 should be able to get to those 3200MHz speeds without an overclockable processor. What was the specific BSoD reason? should be something more than just "Memory Management"
My profile picure is real. That's what I look like in real life. I'm actually a blue and white African Wild Dog.
Ryzen 9 5900X - MSI Ventus 2x OC 3060 Ti - 2x8GB Corsair Vengeance LPX 3200MHz CL16 - ASRock B550 Phantom Gaming ITX/ax
EVGA CLC 280 + 2x140mm NF-A14 - Samsung 850 EVO 500GB + WD Black SN750 1TB - Windows 11/10 - EVGA Supernova G3 1000W
I never got that far into it.. I kept hetting a blue screen Error Code of MemoryManagement, So i turned the XMP settings off and no moe crashes.. I looked into the Memory Clock setting and lowered it to 2666MHz
If you look on this website: https://www.cnet.com/products/asus-rog-strix-z490-e-gaming-motherboard-atx-lga1200-socket-z490/
It lists the MHz compatability and after 2666 they have a (OC)
