So i got a build planed and the parts are as followed,
Case: IN WIN 901
Drive: Samsung Slim DVD/RW
HDD: Seagate Barracuda 7200 3TB
SSD: SAMSUNG 840 Pro Series MZ-7PD512BW 2.5" 512GB SATA III
GPU: Asus GTX 750
PSU: Seasonic Platnium 400W Modular
RAM: Hyper X Blu Red Series 8GB 2x4GB 1600mhz
MOBO: ASUS H87I-PLUS
CPU: Intel Core i5 4430
Any parts suggestion or changes?
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
https://linustechtips.com/topic/135714-mini-itx-build-almost-finalized/
The case will be getting engraved for my mom who does alot of programming so its a mini workstation
|King Of The Lost|
If your getting a workstation for your mom you should focus on more cores rather than stronger cores. Also, why spend such useful money on a SSD that large? save a couple hundred bucks and just get a 256-128GB SSD, in this price range you should be looking for the best bang for your buck. The PSU is way to expensive for the price. You do not want to pay that extra price premium for a fanless power supply because in the longrun it will make no difference I assume that you went for this since it's the only one I could find. http://www.newegg.com/Product/Product.aspx?Item=9SIA3KX16D4722&clickid=wJVSie39SyhczQTxBUyiPTonUkTQGezNWwY1xM0&iradid=97618&ircid=2106&irpid=79301&nm_mc=AFC-IR&cm_mmc=AFC-IR-_-na-_-na-_-na The Inwin 901 has no 3.5" drive bays so you'de have to modify it in order for one to fit. While Barracuda's are faster than WD Blues and less expensive than WD Blacks, they are know to fail much more easily. While you won't be able to overclock, it's always nice to have a descently cool and quiet CPU.  There are way too many flaws with the build as it is. Here's what your build would cost. http://pcpartpicker.com/p/3mGwV This is my idea. http://pcpartpicker.com/parts/partlist/
 Second link isn't working properly you copied the wrong link, and the In-win 901 does have 2 3.5 inch drive bays for it and I the sea sonic Power supply is because of the 80Plus Platinum rating and the slimmer cables which will look alot nicer, and your right about a 512GB SSD I am trying to find just the most reliable SSD for her.
|King Of The Lost|
