so i have this hdd hard drive ive been using since 2013 thats about 2tb and its very slow.... i also have a hard drive thats a ssd but has 200-300 gb... i was wonderring, if i install windows on the ssd and also have the other old hard drive in, will that boost the speed of my computer and i can still use the 2tb one to store files
https://linustechtips.com/topic/1356692-hard-drive-question/
Just now, curiousmind34 said:
Yes! In fact many people use their SSD as a boot drive and a hard drive for mass storage.
I would just run a diagnostic to make sure the old drive is working without any errors and defrag it image.png.4ec5b973b3981646e356b22ac04542a4.png
I was actually trying to defrag it yesterday, but the app doesnt open for me, no matter how many times i open it, or even open it as administrator
https://linustechtips.com/topic/1356692-hard-drive-question/#findComment-14873291
well, when you install windows on your ssd and plug your hard drive in, it should hopefully work then.
Since your install might be a bit bugged, I would just install a fresh copy from a usb drive to the ssd.
https://www.microsoft.com/en-us/software-download/windows10
https://linustechtips.com/topic/1356692-hard-drive-question/#findComment-14873294
uh oh, as i tried opening defrag  i just got this error, is this bad? image.png.43703f84acfd3fcd8f9e5018fb65a1f4.png
https://linustechtips.com/topic/1356692-hard-drive-question/#findComment-14873296
2 minutes ago, noicegamer said:
uh oh, as i tried opening it i just got this error, is this bad? image.png.43703f84acfd3fcd8f9e5018fb65a1f4.png
that is not good, it means your drive might be failing, which usually happens after several years or a lot of use accumulated over time. I would follow the instructions and click the notification to try to repair drive errors, but it might be an error on a hardware level.
I would copy any important files you can't just download off the internet to the SSD ASAP after restarting in case the drive's state gets worse.
https://linustechtips.com/topic/1356692-hard-drive-question/#findComment-14873299
