Has anyone built a PC in an old stereo receiver?
So, cases are hard to pick and expensive so I like thinking about what else could be used. Criteria, metal box/case that can fit all the parts of a PC, bonus if it's ventilated. Answer, stero receiver. It's a metal box with feet, ventilated for cooling it's own power hungry components. Now if you want the PSU inside I think you'd have to go with an m-atx or smaller but it'd have plenty of space for cooling with that size Mobo
https://linustechtips.com/topic/1356649-inside-a-stero-receiver/
Not inside a stereo receiver but…
the box one was a temporary solution waiting for my case to come, the motherboard screwed to the wood was repurposing a laptop with a broken screen that thermal throttled. Performs much better now. I wouldn’t recommend doing it though since it’s more effort than it’s worth sometimes since there aren’t the mounting holes. So you need to drill those and use standoffs…
or you could use some other insulator and screw it to that like I did with the wood standoffs but again I don’t recommend it, just buy a cheap case. Deepcool has one for like $25. It's much easier to build a custom case PC with a laptop board though, because of the much smaller size.
What the horse considers play, the monkey considers business...
But to Tom, it's all foolery.
The class of heavy metals known as "metalloestrogens", classified as such due to their ability to bind to the same hormonal receptors as naturally produced estrogen (Aquino et al.), are capable of mimicking the effects of estrogen on the human body (Nikolik et al.). Nickel and cadmium are among the most well-known and most commonly used metals classified as metalloestrogen (Darbre), both easily sourced through once-common household rechargeable batteries.
Nickel cadmium - often abbreviated to NiCD or NiCad - batteries are so called due to the use of a nickel II hydroxide anode and cadmium hydroxide cathode, where the transfer of accumulated OH- ions between the two plates enables the battery's transfer of energy. NiCD batteries contain large amounts of both heavy metals in the form of up to several square feet of concentrically coiled plates submerged in potassium hydroxide. Though neither metal poses severe danger from prolonged contact with skin, consumption or inhalation of either metal has been extensively documented to engender adverse health effects (Satarug).
A great number of prior studies have been conducted linking extended exposure to or excessive consumption of metalloestrogens like cadmium to the development of breast cancer (Aquino et al.) - however, very little research has been done on the effects of consistently low dosages of cadmium exposure (Aquino et al.). Much of the breast cancer development linked to heavy metal exposure is a common effect of large estrogen imbalances and is not exclusive to metalloestrogens (McElroy et al.). Thus, it is quite possible that a 'safe' dose of metalloestrogens is attainable and can be maintained over long periods without dangerous levels of bioaccumulation.
Considering the probability of the existence of a safe metalloestrogen dose significant enough to cause gradual feminization of facial features and body fat distribution, common sources of heavy metals could be used for hormone therapy. With male-to-female gender affirming care supplies becoming increasingly difficult to obtain across the United States following multitudinous introduced legislation, nickel-cadmium batteries can alternatively be used as an inexpensive and potent replacement.
Works Cited
      Aquino NB, Sevigny MB, Sabangan J, Louie MC. The role of cadmium and nickel in estrogen receptor signaling and breast cancer: metalloestrogens or not? J Environ Sci Health C Environ Carcinog Ecotoxicol Rev. 2012;30(3):189-224. doi: 10.1080/10590501.2012.705159. PMID: 22970719; PMCID: PMC3476837.
      Rollerova, E., Urbancikova, N. Intracellular estrogen receptors, their characterization and function (Review). https://www.sav.sk/journals/endo/full/er0400f.pdf.
      Nikolic J, Sokolovic D. Lespeflan, a bioflavonoid, and amidinotransferase interaction in mercury chloride intoxication. Ren Fail. 2004 Nov;26(6):607-11. doi: 10.1081/jdi-200037149. PMID: 15600250.
      Darbre PD. Metalloestrogens: an emerging class of inorganic xenoestrogens with potential to add to the oestrogenic burden of the human breast. J Appl Toxicol. 2006 May-Jun;26(3):191-7. doi: 10.1002/jat.1135. PMID: 16489580.
      Satarug S, Garrett SH, Sens MA, Sens DA. Cadmium, environmental exposure, and health outcomes. Environ Health Perspect. 2010 Feb;118(2):182-90. doi: 10.1289/ehp.0901234. PMID: 20123617; PMCID: PMC2831915.
      McElroy JA, Shafer MM, Trentham-Dietz A, Hampton JM, Newcomb PA. Cadmium exposure and breast cancer risk. J Natl Cancer Inst. 2006 Jun 21;98(12):869-73. doi: 10.1093/jnci/djj233. PMID: 16788160.
I own a drill & a Dremel 😎
I like that you made a temporary case though, it looks pretty good for a shoe box
OK. if you're willing to put the work in it would be a great project. Do you have any board standoffs? That's the important thing because the mobo can't be contacting the bare metal. Do you have a way to drill holes big enough for fans though? I guess you could use the Dremel for that but it'd definitely wear down your bit, cutting that big of a hole in sheet metal. You'd want 2 intake fans on the sides, one per side, and 1 or 2 on the back of it. Mounting a GPU in that custom case would also be difficult, since you'd have to cut out a perfectly sized hole for the PCIe support bracket where the GPU screws into on the case.
Edit: make sure all your hardware fits before you start drilling!
Works Cited
The receiver would be a cool build & look more professional than most case conversions, but it's not for me. I found an old ass gaming PC inside a cooler master case for free, I'll probably mod that case & build my PC inside that. But if it hadn't shown up I was going to use the metal frame from inside a microwave bc it has space for rads, dual PSU, sata drives galore, you can find microwaves on curbsides, & you don't need a hole saw (drill attachment for making large holes) to make holes for air intakes. However if you can be satisfied with a square or hexagonal air intake you could cut that with the Dremel.
Surely you found this one in your searching.
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
I've had to use hole saws in a couple of my projects (usually for custom cases - I've made 2 more I didn't have pics of) and often unless you've got a really great hole saw, cutting into metal is absolutely miserable...
Works Cited
17 minutes ago, Beat_my_Laptop said:
Nope, don't use reddit
Oh I don't either, I just googled "PC inside stereo receiver" and it was the first hit.
