14 minutes ago, Ace_killer887 said:
I recently bout a Corsair iCUE H100i ELITE CAPELLIX Liquid CPU Cooler for my PC and noticed theres a bout a 10 degree difference between the processor and coolant temp is that normal?
From boot? Very normal, it takes a while for watercooler and the CPU to reach equilibrium.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
Yes. Totally normal. The coolant shouldn't actually even be close to the same temperature except when idle. If it actually did get as hot as the CPU, not only would the effectiveness basically go to nil, but it'd likely explode from the pressure buildup inside caused by boiling.
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
