Turn off rgb power in Gigabyte motherboard
Solved by LauriHimself,
4 minutes ago, Mike Kit said:on the amd cooler
aaaaah!
that's nothing to do with your mobo.
assuming you are talking about a wraith prism:
- connect it via the usb cable, not the 4pin
- download the coolermaster software at https://landing.coolermaster.com/pages/amd-ryzen-wraith-prism-rgb-software/
- it should recognize your cooler ad you should be able to disable them
good luck ^^
Featured Topics
rb19 ·
Posted in Graphics Cards0 -
2
yepnew ·
TukangKopi ·
Posted in Networking2 -
2
12
16
