2 minutes ago, RONOTHAN## said:
I have an Arctic Freezer 34 eSports Duo. without any adapters or anything will I be able to use both CPU fans and another 2 regardless?
https://linustechtips.com/topic/1356101-fan-headers/#findComment-14868855
Yeah, you can use all the fan headers on a motherboard at the same time with no issues. One of these adapters would allow you control the fans to be in sync without much effort.
Also, I was looking at photos of the motherboard, and I was only able to find two fan headers, including the CPU fan, so you might need to buy one of these adapters anyway.
https://linustechtips.com/topic/1356101-fan-headers/#findComment-14868885
Are you sure? In my BIOS I can see the CPU one and another 2 that are currently not working
https://linustechtips.com/topic/1356101-fan-headers/#findComment-14868939
I could be wrong, it's very possible I am, but I've been struggling to find where that third header is. If it's showing up in BIOS, it's probably there and I'm just blind
https://linustechtips.com/topic/1356101-fan-headers/#findComment-14868949
ok so using adapters will allow me to fit up to 4 regular fans + the CPU cooler?
https://linustechtips.com/topic/1356101-fan-headers/#findComment-14868958
