Budget (including currency): EUR 1500
Country: Netherlands
Games, programs or workloads that it will be used for: Sims 4, Civilization, Half life (not VR), CS:GO, EuroTruck, AoE 4, WoW
Other details: No PC parts, peripherals not needed, monitor: Samsung 27" QHD 144hz, Freesync
Details: This is going to be my first ever PC build. The last time I installed a graphics card it was into an AGP slot so not exactly knowledgeable about current components.
Ideally, I would like to build a PC mainly meant for gaming even though I do not play the most intensive games, would like something that will not necessarily need an update in the near future.
Current budget is around EUR 1400-1500. I put a list together by looking at suppliers near me.
Component
Price
Motherboard
MSI MAG B550 TOMAHAWK
149
CPU
AMD Ryzen 5 3600
210
Cooler
stock cooler?
Scythe Mugen 5 PCGH Edition
60
GPU
Asus GeForce RTX 2060 DUAL OC Evo
539
Case
Corsair 4000D Airflow
85
RAM
Corsair Vengeance LPX 16GB2 x 8 GB - DIMM - 288-PIN - 3200 MHz - CL16 - 1.35 V
100
Power Supply
CORSAIR RM Series RM850 (2019)
125
SSD
Samsung 970 EVO 1 TB M.2
140
wifi
ASUS PCE-AC68
55
Total: 1403/1463 (depending on cooler)
Any thoughts on the list is much appreciated.
Thanks!
https://linustechtips.com/topic/1356009-my-first-ever-pc-build/
Also, theres cheaper Wifi Available. Mine only costs around 30€ and it has Wifi 6
I would scale down on the Power supply, only a 750w one cause you CPU is Power efficient
Storage also, maybe split between a smaller M.2 NVME (500 or 250GB) and a Harddrive (2TB Seagate for 50€) - thats a storage sweetspot right now
Try to opt for a better GPU, Maybe a 3060(TI) or a 5700XT/6700XT, if you can find one thats still in you budget
https://linustechtips.com/topic/1356009-my-first-ever-pc-build/#findComment-14868251
https://nl.pcpartpicker.com/list/B3XVNP
Intel
https://nl.pcpartpicker.com/list/TCn9Mv
Amd
Intel :
10700kf 8 core cause cheap, you could upgrade to a 10900f but thats uneccesary
Z590 board cause it was cheaper than the z490 version of the board
Fuma 2 cooler to cool this nuclear reactor down
Amd :
5800x 8 core, should be better than the 10700kf in gaming and efficiency
B550 a pro cause ik you arent gonna oc anyways
A cheap 6 heatpipe cooler from scythe
Both :
cheaped out on everything other than the psu
Gpu is up to you
https://linustechtips.com/topic/1356009-my-first-ever-pc-build/#findComment-14868488
