Help choosing RAM
Solved by Somerandomtechyboi,
5 minutes ago, N 3 P T U N E said:When I hover over the orange "Your Score" here's what I see:
Multi Core: 9348 pts, 8 cores, 16 threads @ 3.6 GHz
Single Core: 947 pts,
So is it boosting up above 3.6ghz in cpuz?
If it isnt then yea theres your problem
Go into the bios and set a 4.7-4.9ghz all core w 1.25v or lower for efficieny or just mess with dynamic oc for more performance but thats alot of trial and error
