20 minutes ago, anudab said:
I just need a window to shut down and protect my hardware from an power outtage for that much VA do i need in my UPS .my build is,
750-900VA UPS from a reliable brand like APC is good enough.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1355181-ups-for-my-pc/#findComment-14862365
Same question but heres my build
CPU: AMD Ryzen™ 3 PRO 4350G
RAM: Vengeance LPX / Ripjaws 5 / HyperX - 3200MHz - CL16 - 2x8GB kit
PSU: CoolerMaster MWE 550W 80+Bronze
Storage: WD 250GB SN550 NVMe SSD  + WD Blue 1TB 7200RPM HDD
CASE: Antec NX310
https://linustechtips.com/topic/1355181-ups-for-my-pc/#findComment-14862371
CASE: Antec NX310
Dont hijack someone's thread. But yeah, considering that 650VA is the smallest sized UPS you can get most of the time, thats the default answer.
https://linustechtips.com/topic/1355181-ups-for-my-pc/#findComment-14862374
Thank you! Sorry about that. Since it was a similar question, I thought of asking here instead of creating a new thread.
https://linustechtips.com/topic/1355181-ups-for-my-pc/#findComment-14862381
