First build, opinions needed
Solved by IkeaGnome,
7 minutes ago, katixea said:Thanks a bunch! Does the rest of my parts list look okay?
Did you get that cooler for the RGB? Don't buy Windows at full price. There's places you can get OEM keys for cheap.
If you didn't get that cooler for the RGB, here's a double tower that is $5 cheaper and it'll have more room for OC if you wanted to do that later.
Other than that, it looks good. 3600 might be a little faster than you need on Comet Lake, but there's nothing wrong with that. The 3200 kit of that same ram is the same cost.
