Greetings,
My background:
I'm currently saving up for a new PC.  I know HOW to build my own, and have so in the past.  I've been upgrading various parts in my current PC over the past 10 years (and as such, the only 'part' that is the same as when I bought it, is the case :D ).
However, for various reasons, I've been saving up for a new PC and should have the money for my desired specs by the end of the month.
I do NOT want a 'pre-built' system, I am aiming for a 'custom-built' one.  As mentioned, I do know how to build my own, but I really do not like doing it (I'm more of a software guy).
I was planning on CyberPowerPC, as my last experiences with them (~10 years ago) was good.  But on researching, I've seen ...'less than stellar' reviews of them for the past couple of years, so I have my reservations.  (however, this was for pre-built systems and I can't really find any reviews on custom-build ones)>
I have since also looked into iBuyPower, NZXT, and a few others with not much better reviews.
Now I am fully aware that typically people leave more negative reviews than positive ones, and many forums are populated by the 'exceptional' bad lemons rather than the general quality of any particular brand.
Anyone have feedback on recent experiences with a custom build from any of these companies?
Thank you.
https://linustechtips.com/topic/1354975-custom-build-pc-maker-considerations/
Buy local from a small computer shop, tell them what parts you want, and let them do all the work.
If you have issues, you can go back to them face to face to get it resolved.
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
I'll consider that; but I live in small town where that might not be possible (no car either).  Thanks!
Your other option is to just use your knowledge to save on most of the work by buying whatever brand has the best value, and just cleaning up the couple things they assemble poorly yourself.
While not ideal (nor should it be needed at all), it'll save you most of the hassle. You just might have to re-seat a few things, swap some fans around... Bam, you're done.
Primary Gaming Rig:
Ryzen 5 5600 CPU, Gigabyte B450 I AORUS PRO WIFI mITX motherboard, PNY XLR8 16GB (2x8GB) DDR4-3200 CL16 RAM, Mushkin PILOT 500GB SSD (boot), Corsair Force 3 480GB SSD (games), XFX RX 5700 8GB GPU, Fractal Design Node 202 HTPC Case, Corsair SF 450 W 80+ Gold SFX PSU, Windows 11 Pro, Dell S2719DGF 27.0" 2560x1440 155 Hz Monitor, Corsair K68 RGB Wired Gaming Keyboard (MX Brown), Logitech G900 CHAOS SPECTRUM Wireless Mouse, Logitech G533 Headset
HTPC/Gaming Rig:
Ryzen 7 3700X CPU, ASRock B450M Pro4 mATX Motherboard, ADATA XPG GAMMIX D20 16GB (2x8GB) DDR4-3200 CL16 RAM, Mushkin PILOT 1TB SSD (boot), 2x Seagate BarraCuda 1 TB 3.5" HDD (data), Seagate BarraCuda 4 TB 3.5" HDD (DVR), PowerColor RX VEGA 56 8GB GPU, Fractal Design Node 804 mATX Case, Cooler Master MasterWatt 550 W 80+ Bronze Semi-modular ATX PSU, Silverstone SST-SOB02 Blu-Ray Writer, Windows 11 Pro, Logitech K400 Plus Keyboard, Corsair K63 Lapboard Combo (MX Red w/Blue LED), Logitech G603 Wireless Mouse, Kingston HyperX Cloud Stinger Headset, HAUPPAUGE WinTV-quadHD TV Tuner, Samsung 65RU9000 TV
