So I accidentally bent my phone a bit in my sleep and it's kind of noticeable but it still works fine but I don't want my parents knowing I bent it Is there anyway to fix it (Unbend it) without using a Repair kit?
Edited by Blcoky
Typo
https://linustechtips.com/topic/1354811-need-help-asap/
24 minutes ago, Blcoky said:
without using a Repair kid?
Seriously though you should do two things:
1) Don't sleep with your phone in your hands, on your pillow etc. Bad habit, when it is time to sleep / nap put the phone away.
2) Tell your parents because that is the right thing to do and they will know what to do (most of the time), or look at this way: if they try to unbend it and the glass shatters it will be on them. 🙂
https://linustechtips.com/topic/1354811-need-help-asap/#findComment-14859930
Yeah I wanna tell them but they're kind of strict 😬
https://linustechtips.com/topic/1354811-need-help-asap/#findComment-14859949
They'll be less angry if you tell them what happened instead of trying to hide it and causing more issues for yourself to explain to them..
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1354811-need-help-asap/#findComment-14859980
As a guy who tried to hide dropping his phone in the water from his strict parents *cough* years ago, can confirm the best method is to own up to it. My phone also worked fine for a while afterwards, but eventually it kicked the can, and they found out. Wasn't fun....
Recommend telling them, but if you won't then for trying to straighten it I would do that by pressing it on a flat surface, not bending it in your hands because the flat surface will ensure you don't go too far or apply too much uneven pressure.
Also, Biohazard above had it right, avoid sleeping with the phone in your bed, nightstand is as close as it should get.
| 2014 Retina MacBook Pro 13" |
My gaming desktop -- |Intel Core i7-3820 | ASUS P9X79 Deluxe | 16gb 2133mhz G.Skill Ripjawz X | ASUS DUAL GeForce GTX 1060 6GB | Fractal Design Define R5 | Seagate Barracuda 1TB 7200rpm HDD | SeaSonic 760XP2 | Xigmatek Gaia CPU Cooler | LG22MC57HQ 1080p Monitor | Azio MGK1 Keyboard | Logitech G300s Mouse | HyperX Cloud Headset | Windows 10 Pro Insider |
https://linustechtips.com/topic/1354811-need-help-asap/#findComment-14860232
I'll probably just end up telling them cause If I try to straighten it even on a flat surface I have alot of risk of breaking the glass but it still works just fine like the screen is still responsive and works just fine, Thanks for trying to help Though 😊
https://linustechtips.com/topic/1354811-need-help-asap/#findComment-14860275
