Patterned blinking modem/desktop ethernet
i been having trouble with my Ethernet connection that i am not entirely sure what exactly the problem is.
Story goes like this
I am in my room with my computer. I have a really long Ethernet cable connecting the modem directly to my Computer which is 20 meters away by cable length, at first i get a "No Network" it was just an easy step of disabling and enabling my network device but later on it didn't help anymore so i use a router, thinking that the wire is too long for the signal to reach to my computer, used a meter long Ethernet cable to my computer from the router and then the disabling and enabling the network device came back but at least i have internet. then days later it stopped working again, feeling sure that it's because of my Ethernet cable being too long i cut off 5 meters off and it stopped being a pest but now there is a new problem. Both Router and the Ethernet jack on the I/O makes a pattern of blinking for 5 seconds then turns off for 3 seconds.
resetting the router fixes the problem but i'm sure it will come back to ruin my game!
what did i do wrong? @_____@
https://linustechtips.com/topic/135463-patterned-blinking-modemdesktop-ethernet/
Ethernet cable shouldn't be bad at 20m, have you tried reinstalling your network drivers? Or replaced the cable?
                    Fractal Design Arc Midi R2 | Intel Core i7 4790k | Gigabyte GA-Z97X-Gaming GT                              Notebook: Dell XPS 13
                 16GB Kingston HyperX Fury | 2x Asus GeForce GTX 680 OC SLI | Corsair H60 2013
           Seasonic Platinum 1050W | 2x Samsung 840 EVO 250GB RAID 0 | WD 1TB & 2TB Green                                 dat 1080p-ness
yes and no since i don't have a 15 meter long Ethernet cable to replace it @___@
but what reason could the Ethernet cable make such a pattern to the router?
It could possibly be the router.
