CPU fan error
Go to solution Solved by Skiiwee29,
2 minutes ago, deerie said:
Where can I disable it? I use an asus prime X570 pro mobo.
should be in your BIOS under the fan control section, you should be able to disable the alert on it.
This occurs when there is nothing plugged into the CPU Fan header on your motherboard.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1354484-cpu-fan-error/#findComment-14857685
1 minute ago, deerie said:
What should I do to fix it?
If you have nothing plugged into the dedicated Fan header on your motherboard, you can either plug a fan in to have something on there, or you can disable it in the BIOS to not alert/warn.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/1354484-cpu-fan-error/#findComment-14857701
https://linustechtips.com/topic/1354484-cpu-fan-error/#findComment-14857712
Community Standards
"Beast Mode"
https://linustechtips.com/topic/1354484-cpu-fan-error/#findComment-14857715
