Hi,
I have built a new PC but kept my 1050ti for now
The GPU was on DP (Display Port) on the old PC and everything was working fine.
When I built the new PC, the MB sends good DVI signal, but when I switch to the GPU in the BIOS, the display port doesn't get signal at all, and when I plug the DVI into the GPU, it gets signal until the windows boot screen dissappears, then the monitor is still on but no picture (it's getting signal but nothing's showin up)
I tried using teamviewer to reinstall the drivers while the monitor was hooked up to the GPU, but I only get a picture when the driver uninstalls - as soon as it installs again, lost picture.
Any kind of suggestion will do
Thank you
PS: I have tried another monitor, same result - after it boots it just shows a blank screen. Also i noticed that the bios screen and boot screen are not the correct resolution while on GPU-DVI
https://linustechtips.com/topic/1353221-gpu-problem/
