Budget (including currency):
between 1000-1500 CAD maybe a bit more if its worth it
Country: Canada
Games, programs or workloads that it will be used for: occasional gaming, mostly for university. I am looking to be able to run two 4k monitors if the budget allows.
Other details: The budget does not include peripherals. no case preference.
Its been a few years since I kept up with current hardware. The last time I built a computer was in 2013 haha. I'm looking to start a completely fresh build.
Thanks in advance.
 CPU Intel Core i5-4670K 4.2GHz Quad-Core    CPU Cooler Corsair H100i 77.0 CFM Liquid     Motherboard MSI Z87-G45 Gaming ATX LGA1150   Memory Patriot Viper 3 16GB (2 x 8GB) DDR3-1600     Storage Samsung 840 Pro Series 128GB 2.5" SSD     Seagate Barracuda 2TB 3.5" 7200RPM    Video Card MSI GeForce GTX 770 2GB   Case Cooler Master Storm Scout 2 (Black) ATX Mid Tower   Power Supply Corsair 750W ATX12V / EPS12V  Optical Drive none Operating System Microsoft Windows 7 ultimate
https://linustechtips.com/topic/1353130-new-build-help/
17 hours ago, Somerandomtechyboi said:
Will you be doing any overclocking?
What settings and resolution do you expect for your games?
Possibly a light overclock nothing crazy. I would only need 1080p for gaming but the more the better. As long as it can hold 60fps I'd be happy.
https://linustechtips.com/topic/1353130-new-build-help/#findComment-14848868
