Won't POST
Solved by VectorTech,
1 minute ago, Feyza said:It's all plugged in, just checked
Move the ram to the further slot from the CPU, it's labeled as slot 1 and you'll want it to be in there.
Next try taking your GPU out and see if you get anything from the on board graphics utilizing the VGA / HDMI out on your motherboard and report back.
1
2
kerriya ·
Posted in Cases and Mods8 -
octester ·
Posted in Troubleshooting6 -
DavidPatrascu ·
Posted in General Discussion7 -
2
3
play_circle_filled
Latest From ShortCircuit:
