11 minutes ago, Lilunderscoreu said:
My fan power cord has 3 pins and three motherboard header has 4. Is it okay to plug the 3 pin into the 4 pin header?
A 3-pin fan is a DC fan controlled by changing the voltage.
A 4-pin fan is a PWM fan controlled by giving pulses while maintaining the same (12V) voltage.
The 3-pin fans use a pin for 12V, ground and data (to read RPM) while a 4-pin will use 12V, ground, data and PWM signal pin.
A motherboard header with 4 pins can usually (99.9%) do both so no worries, plugging in a 3-pin fan in a 4-pin header works just fine.
