Hey, I was wondering if someone could help me choose a motherboard for my ryzen 5 5600x cpu. I was wondering if anybody could help me find a motherboard thats compatible I was thinking of a b550-f (Asus), seller does say its compatible with 5000 series but that varies, after a bit of reasearch as well their are some major flaws with it. Thanks!
https://linustechtips.com/topic/1352632-cpu-mobo-help/
It doesn't "vary," unless you mean that it might require a BIOS update. It has BIOS flash without needing a CPU installed, so this is a trivial matter.
It would help us make recommendations if you elaborated on what flaws you're concerned about.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1352632-cpu-mobo-help/#findComment-14843560
Yeah, I have figured it out didn't make it clear on my end sorry about that the flaws were more on the aio I selected blocking the ram slots
https://linustechtips.com/topic/1352632-cpu-mobo-help/#findComment-14843593
