Budget (including currency): £1000 pounds
Country: uk
Games, programs or workloads that it will be used for:
this is my part list, I wanted you guys to check it out to see if it's good for gaming.
https://uk.pcpartpicker.com/list/42bZYg
https://linustechtips.com/topic/1352610-building-a-new-pc-need-help/
Seems pretty good, though that cpu defenetly doesn't need that cooler, unless you are going to overclock. You could get away with a ryzen 5 with stock cooler, mine runs very well, so if you don't take that cooler you could up your cpu budget and get a better cpu. But its up to you, the rest is seems good.
Also if you really want a cooler, you can get a arctic freezer one fan or duo for 30-40 bucks, defenetly no need for a 60-80 buck cooler though, it's also really good for that price, keeps even ryzen 7 or sometimes not overclokced ryzen 9s at low temps
