Budget (including currency): Preferably under £1000 but can go to £1300 Max
Country: England
Games, programs or workloads that it will be used for: Streaming and playing big games such as GTA and COD.
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I just need an idea of what to buy and how to put it together. Im very new but Would like 1080p because I got a new 144p monitor 🙂
https://linustechtips.com/topic/1351727-building-new-pc-need-help/
PCPartPicker Part List
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor  (£258.77 @ Amazon UK)
Motherboard: MSI B550-A PRO ATX AM4 Motherboard  (£99.99 @ AWD-IT)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3600 CL18 Memory  (£69.99 @ Box Limited)
Storage: Kingston A2000 500 GB M.2-2280 NVME Solid State Drive  (£47.49 @ Amazon UK)
Video Card: Palit GeForce RTX 3060 12 GB StormX Video Card  (£589.79 @ Overclockers.co.uk)
Case: Metallic Gear Neo Air ATX ATX Mid Tower Case  (£59.99 @ Amazon UK)
Power Supply: Corsair TXM Gold 550 W 80+ Gold Certified Semi-modular ATX Power Supply  (£62.99 @ Amazon UK)
Total: £1189.01
Generated by PCPartPicker 2021-06-28 22:29 BST+0100
if you can wait for stock -
Storage: Samsung 980 1 TB M.2-2280 NVME Solid State Drive  (£89.54 @ Scan.co.uk)
Video Card: Asus GeForce RTX 3070 8 GB TUF GAMING OC Video Card  (£500.00)
Power Supply: Corsair TXM Gold 750 W 80+ Gold Certified Semi-modular ATX Power Supply  (£75.98 @ Amazon UK)
Total: £1154.26
Generated by PCPartPicker 2021-06-28 22:36 BST+0100
geometry is hard
b550 > x570
For all the parts are they put in the same as most other PC parts or are they different? because i have never build a PC in my life and am completely clueless about assembly. I have only seen like 10 videos on YouTube of how to put it together
It should be in the same order. The parts are different but the order you put the parts in is the same.
geometry is hard
b550 > x570
