I am planning on building a custom pc and am deciding which components to have installed. Listed below, is there any changes I should make? I just want a PC that can run most games on high and be able to stream them too, I also prefer intel over AMD.
CPU - Intel i9-10900K
GPU - MSI GeForce RTX 3070 Ti
Motherboard - MSI MPG Z490 Gaming Plus: ATX, 2x M.2
RAM - 32GB (2x16GB) DDR4/3200mhz Dual Channel Memory (HyperX Fury w/Heat Spreader)
SSD - Intel 1TB 3500mb/s read,2500mb/s write
HDD - Seagate Barracude 1TB 6gb/s 7200RPM
PSU - Cooler Master MWE 750w 80+ Bronze
Cooling - Cooler Master Masterliquid Lite 240 Liquid Cooling System w/ 240mm Radiator, possibly an additional 3x120mm 1350 rpm fans
https://linustechtips.com/topic/1351465-custom-pc-build/
What kind of FPS are you looking for? And what games are you going to play?
https://linustechtips.com/topic/1351465-custom-pc-build/#findComment-14834846
Mostly Call of Duty, Battlefield and World of Warcraft. I want steady fps on all 3 at max settings whilst streaming. One monitor will have my game, the other monitor will have my streaming control/plugins etc
https://linustechtips.com/topic/1351465-custom-pc-build/#findComment-14836871
If you are set on going with Intel 10th gen then the i9 10850K might be cheaper.
That cooler won't handle the 10 core cpu though. I would suggest a better one like the Arctic Liquid Freezer II 360mm or a good dual tower air cooler (Noctua D15, BeQuiet DRP3, Scythe Fuma 2 etc).
I would also suggest a better psu. Have a look through the tier list and stick with Tier A/B.
Which Intel SSD is that ?
https://linustechtips.com/topic/1351465-custom-pc-build/#findComment-14836918
