14 minutes ago, rockyroller said:
LED strips either need to be plugged into the mother board RGB headers (you have to find out where they are in the motherboards manual, not all motherboards have them) or into a third party item called a RGB LED Controller.
Ok so how do I find it or
https://linustechtips.com/topic/1351390-led-strip-3-pin-header/#findComment-14834244
to find out you could download and run CPUID CPU-Z and in that look up what the motherboard is, then google search for the makers manual
this is what they might look like
https://linustechtips.com/topic/1351390-led-strip-3-pin-header/#findComment-14835328
