Hello. I am experiencing crashing when I try to install drivers, or it just happens randomly.  My screen goes black, then it either restarts or I get a “diagnosing your pc” and get the windows recovery screen. Sometimes it can just stay black too. If anyone would be kind enough to help me, I can provide screenshots and answers to any question.
I am fairly confident it is not the GPU, since I tested and swapped it and it did not change anything. I have not seen any issues with the motherboard battery too. Ram seems okay, tried using 1 stick with both.
I’m thinking that the motherboard would be the issue.
I have good cooling on all of my component and case, except for my CPU which has the stock cooler.
Note : I noticed that sometimes the gpu fans stop spinning while the computer is on, is this normal?
I made my own pc, and it is obviously my first one.
Specs :
Windows 10 Pro
Ryzen 5 3600  (with stock cooler)
EVGA GeForce RTX 3060
B550M DS3H
Antec HCG750 Gold
Crucial P5 M.2 1TB
Crucial Ballistix Gaming Memory 16GB
https://linustechtips.com/topic/1350770-unexpected-crashes-and-installation-errors/
What drivers?
Crucial P5 M.2 1TB
Your only drive? Is it new?
Desktop: i9-10850K [Noctua NH-D15 Chromax.Black] | Asus ROG Strix Z490-E | G.Skill Trident Z 2x16GB 3600Mhz 16-16-16-36 | Asus ROG Strix RTX 3080Ti OC | SeaSonic PRIME Ultra Gold 1000W | Samsung 970 Evo Plus 1TB | Samsung 860 Evo 2TB | CoolerMaster MasterCase H500 ARGB | Win 10
Display: Samsung Odyssey G7A (28" 4K 144Hz)
Laptop: Lenovo ThinkBook 16p Gen 4 | i7-13700H | 2x8GB 5200Mhz | RTX 4060 | Linux Mint 21.2 Cinnamon
Any other problems that were evident before trying to install drivers ?
Well, unexpected crashes, pretty sure they started before the driver installation, but they cause crashes too. I am thinking of replacing the motherboard and seeing how it goes. I bouht a fairly cheap motherboard and I wouldn’t be surprised if it was the issue.
