No Post Nothing works
Go to solution Solved by Robchil,
is the GPU out and plugged monitor cable directly into your mainboard?
Hi all I need some serious help and this seems like the best place best to ask! I would really appreciate it,
I have a Aorus Z270 gaming 7 Rev.1.0
 I changed a setting in the bios with was secure boot and now, I don’t get any post screen, I can’t press Del to enter bios, windows does not boot it the same on both Bios 1&2 its a mess, I’ve unplugged all HDD’s. And still nothing how can I solve this please help me
https://linustechtips.com/topic/1350643-no-post-nothing-works/
1 hour ago, Tan3l6 said:
Do you know how to clear cmos?
Just to explain if you dont. Clearing cmos resets all BIOS settings.
To do that just connect two of those pins on the motherboard, labelled "CLR_CMOS" for a second with metal object:cmos.thumb.png.0542bcb385e53671261c1a87f1b19d68.png
So did the pin’s there also a switch on the MB at top, I’m still Black screen
https://linustechtips.com/topic/1350643-no-post-nothing-works/#findComment-14828969
