Just now, 8tg said:
Warm soapy water and a nail brush works very well from my experience.
If you don’t have a nail brush get one because clean nails are also nice.
Alternatively just a washcloth and a lot of scrubbing.
Thanks  mate
https://linustechtips.com/topic/1349670-mousepad-cleaning/#findComment-14820979
I pour a tiny bit of laundry detergent in semi-warm water in the bathtub and slowly scrub in circles with a wash cloth or a sponge. Rinse and repeat 1-3 times and dry for 4-8 hours, mousepad should be good as new.
Note: I have stitched edges on my mousepad, so if you have a non-stitched edge mousepad then you could risk it fraying.
https://linustechtips.com/topic/1349670-mousepad-cleaning/#findComment-14822489
