Ryzen RAM Problem
Go to solution Solved by jwwagner25,
8 minutes ago, BarisBayraktar said:
Thank you!
it depends;
on HP prebuilt that come with APU, usually you CANNOT change the default reserved 2GB; even if the system has a discrete GPU. So if you have 16GB of ram you will never be able to use more than 14GB no matter what since BIOS is locked down.
5 minutes ago, BarisBayraktar said:
Is this true that Ryzen uses more RAM than Intel i series?
I've never heard such a thing. It's not true.
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
https://linustechtips.com/topic/1349580-ryzen-ram-problem/#findComment-14820127
Maybe you are thinking about the APUs
GAMER
SPEC: HYTE Y60 White/Black + Custom ColdZero ventilation sidepanel – AMD Ryzen 7 9800X3D + ASUS ROG RYUJIN III 360 – G.SKILL Trident Z5 Neo RGB DDR5-6000 64GB CL30-40-40-96 – ASUS RTX ROG ASTRAL 5080 OC – ASUS ROG STRIX B850-E GAMING Wi-Fi – Samsung EVO Plus 1TB, Samsung EVO Plus 1TB – Corsair HX1200i
GEAR: Samsung Odyssey Neo G9 G95NC 57" – ASUS ROG Harpe Ace Aim Lab Edition Wireless – ASUS ROG Claymore II Wireless –
ASUS ROG Sheath BLK LTD – FiiO K7 DAC/AMP + Beyerdynamic DT 770 PRO X (Limited Editon), Edifier S351DB, Steelseries Arctis Nova Pro Wireless
Home LAB
SPEC: Corsair 4000D Airflow TG – AMD Ryzen Threadripper 1950X – Corsair Vengeance LPX 128GB (CMK32GX4M2D3000C16 x4) – ASUS GeForce GT710 1GB – ASUS ROG Zenith Extreme – ROG AREION 10Gbps – Toshiba XG6 1TB, WD 256GB, Kioxia 256GB – Corsair HX750
GEAR: Philips 346B1C 34" – Logitech MX Keys – Logitech M705 – Jabra Evolve2 75
Racing SIM
GEAR: Sim-Lab GT1 EVO Sim Racing Cockpit + Integrated Vario Triple mount – Svive Racing D1 Seat – MSI 325CQRXF 32" x3 – Simagic Alpha Mini + Simagic GT4 (Dual Clutch) – CSL Elite Pedals V2 – Logitech K400 Plus
https://linustechtips.com/topic/1349580-ryzen-ram-problem/#findComment-14820132
1 minute ago, BarisBayraktar said:
Yeah APUs
APU's use system memory / RAM, that is correct yes.
GAMER
Home LAB
Racing SIM
https://linustechtips.com/topic/1349580-ryzen-ram-problem/#findComment-14820140
2 minutes ago, BarisBayraktar said:
Especially laptop APUs right?
From what I've seen, AMD's APU's always use 2GB of system memory by default. But I think you can decrease and increase it.
GAMER
Home LAB
Racing SIM
https://linustechtips.com/topic/1349580-ryzen-ram-problem/#findComment-14820153
Thank you!
Lenovo IdeaPad 700 | i7 6700HQ | GTX 950M | FHD 15.6" IPS
Xiaomi Mi 9T | Snapdragon 730 | FHD 6.39" AMOLED | 48 MP IMX 582
https://linustechtips.com/topic/1349580-ryzen-ram-problem/#findComment-14820157
Thank you!
it depends;
https://linustechtips.com/topic/1349580-ryzen-ram-problem/#findComment-14820194
23 hours ago, Tan3l6 said:
You can change the dedicated RAM in BIOS most likely.
that is total speculation, I wouldn't count on it. Most OEM's lock down the BIOS especially on laptops. I would lean towards assuming it CANNOT be changed unless or until you know otherwise.
https://linustechtips.com/topic/1349580-ryzen-ram-problem/#findComment-14822667
