Help!!
Go to solution Solved by Herman Mcpootis,
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  (£172.80 @ Amazon UK) 10400/11400/10600k and B460/560 board is an option if you want to wait for prices to drop on GPUs.
Motherboard: Asus ROG STRIX B450-F GAMING II ATX AM4 Motherboard  (£79.99 @ Box Limited)
Memory: Crucial Ballistix 16 GB (2 x 8 GB) DDR4-3000 CL15 Memory  (£67.23 @ Amazon UK)
Storage: Kingston A2000 500 GB M.2-2280 NVME Solid State Drive  (£47.48 @ Amazon UK)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  (£43.62 @ Amazon UK)
Video Card: MSI GeForce GTX 1050 Ti 4 GB Video Card  (£175.99 @ Aria PC) still overpriced but it's a legit option if you can't wait.
Case: Fractal Design Focus G ATX Mid Tower Case  (£29.58 @ Amazon UK)
Power Supply: Corsair TXM Gold 750 W 80+ Gold Certified Semi-modular ATX Power Supply  (£75.99 @ Currys PC World)
Total: £692.68
Generated by PCPartPicker 2021-06-22 02:06 BST+0100
Budget:700
Country:uk
im looking to build a decently powerfull pc for gaming and streaming streamlesly
at the moment im going for:
CPU:amd ryzen 5 3400g 3.7gh quad core proccesor
COOLING:corsair icue h100i rgb pro liquid cooler
MOTHERBOARD:msi b450 tomohawk max atx am4 motherboard
MEMORY:warhawk 32gb (2x16) ddr4-3600
STORGE:1tb ssd
POWER SUPPLY:nzxt c 750 w 80+ gold fully modular atx supply
i have the case already and atm the cost for the rest is 662.28 does anyone have any suggestions for changes to make or to reduce costs??
https://linustechtips.com/topic/1349434-help/
Steaming "streamlessly"?
You don't need a 240mm AIO for a 3400G. The stock cooler is fine.
You don't really need 32GB of RAM either.
Unless you plan on upgrading this with a 3080-level card or better you don't need a 750W power supply.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1349434-help/#findComment-14818947
2 minutes ago, turkish_oasis said:
Budget:700
Country:uk
STORGE:1tb ssd
make the ram 16bg (2x8) cl16 3200mhz and use stock cooler for cpu then get a 750w bronze or sliver psu and get a gpu with the extra money
https://linustechtips.com/topic/1349434-help/#findComment-14818950
He doesn't need 750W regardless of 80+ rating, and 80+ is not an indicator of quality. 80+ Silver is also extremely rare.
https://linustechtips.com/topic/1349434-help/#findComment-14818953
1 minute ago, turkish_oasis said:
u reckon you could just give me a full new build as tht would be easier for me? as i obviously dont really know what im doing?thanks
Do you plan on getting a GPU later on? If so, roughly what would you be looking at? 60 or 70 series?
Also, make sure you quote people so they see you replied. Not everyone follows the thread.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1349434-help/#findComment-14818965
Total: £692.68
https://linustechtips.com/topic/1349434-help/#findComment-14819012
